IMX219-83 Stereo Camera Waveshare
Posted: Fri Apr 10, 2020 10:29 am
by JtLadD
This is very interesting to me as I already
have a Leica BLK3D which is essentially the same with the addition of a laser distance metre which measures the distance to the approximate (?) centre of the image. This gives scale and orientaion of the pairs.
One other thing about the BLK3D that I do not yet see from Stereopi users is that the cameras are offset both horizontally and vertically which I think helps with the stereo computation.
Re: IMX219-83 Stereo Camera Waveshare
Posted: Fri Apr 10, 2020 10:43 am
Hi JtLadD,
Actually, when you have both horizontal and vertical offsets, it is similar to rotating horizontal offset at some angle. But your images should be rotated too.
I don't think that basic OpenCV calibration procedure will manage this out, but I'm curious to try this.
You see, "double axis offset" useful for detection of a disparity for horizontal lines (which are mostly invisible by horizontal offset), and also gives you some more distance between cameras (stereo base), as it is a diagonal size of a rectangular setup.
As for IMX219-83 (mentioned in our
last update) - we are waiting for delivery of this item to test it. It looks interesting, as it is cheaper than a couple of camera modules, but also has additional features (like IMU) onboard. Also it has a relatively small FOV 83/73/50 degree (diagonal/horizontal/vertical). I will try to replace optics to wide angle, as used optics looks like a classic M12.
Posted: Sat Mar 19, 2022 4:58 pm
by stoffel61
is there any news about tne IMX219-83 as it is in the market now?
Best regards,
Chris
Posted: Mon Apr 04, 2022 10:55 am
Hey stoffel61,
It just works, no special updates here.
I also found that the plastic base for the optics used on IMX219-83 is physically compatible with a few other Waveshare M12 cameras. I.e., you can swap them using just 2 screws on the back side of the camera.
