command line
command line
How can I set up the stereopi to access the command line? I would like to run scripts to take pictures at specific time intervals
Re: command line
If you use SLP variant of the operating system (which is the default delivered with the kit), remote console access is enabled by default through SSH protocole. See https://wiki.stereopi.com/index.php?tit ... 99_section for credentials.
Re: command line
Stereomaton thank you!
Bchamp, do not forget to unlock a filesystem before changes! Also we have MC installed in SLP, so you can use it if you like.
