I decided to open this thread to list all supported modules tested, and also drivers installation procedure for unsupported modules.
<><>This topic will be updated as soon as we test new devices.<><>
For unsupported modules we recommend to use this perfect installation script from MrEngman (details on RPi forum)
Installation:
sudo wget http://www.fars-robotics.net/install-wifi -O /usr/bin/install-wifi
sudo chmod +x /usr/bin/install-wifiCode: Select all
sudo /usr/bin/install-wifiAlfa AWUS036NEH, 2.4GHz, device ID 148f:3070 (supports monitor mode for WiFi broadcast)
Netgear WNA1000M, 2.4GHz, device ID 0846:9041
Modules works after MrEngman drivers installation:
Tp-link Archer T2U (AC600) !!! NON 'Plus' version!!! , 2.5/5GHz, device ID 148f:761a
ASUS USB-AC53 Nano, 2.4/5GHz, device ID 0b05:184c
Not working modules (even with MrEngman's drivers)
Tp-link T2U Plus (AC600), 2.4/5GHz, device ID 2357:0120 - not working
<><><>If you have your tests results - please share it with us! We'll update our list of supported modules!<><><>
