Suggestions for the next iteration
DaveDischord
I wasn't sure if you're accepting ideas for the next hardware iteration but I would like to make one suggestion: I2C header, Qwicc or whatever works. It'd keep some projects that don't need a full GPIO header from getting cramp.
Re: Suggestions for the next iteration
Hi Dave,DaveDischord wrote: Sat Sep 28, 2019 10:27 pm I wasn't sure if you're accepting ideas for the next hardware iteration but I would like to make one suggestion: I2C header, Qwicc or whatever works. It'd keep some projects that don't need a full GPIO header from getting cramp.
Thank you for your ideas!
We're considering to do extension boards, but not sure which to start with.
Actually, for a simple I2C connection you may use GPIO of the StereoPi and wires like Dupont (popular for Raspberry and Arduino). This helps you to avoid using all the GPIO pins by header.
