Port to Oculus Quest
I already mentioned here, that i tried to run the Go App on Quest without success.
Seems that there are only small changes needed, because generally Go Apps should run on Quest.
I did a new threat to get a bit more focus on that, cause a many people own a quest and i think it's THE headset for that kind of stuff.
Cu Knochi
Cu Knochi
Re: Port to Oculus Quest
Hi Cu Knochi,
You see, it is the most painful task we have now. All the teams we've contacted to port our application to Oculus was unable to solve this task.
At this moment we're still in a process with 2 teams. In a case of success we will release native Oculus Go/Quest application.
By the way, for uploading our Android application to Oculus Go we've changed manifest file. If you can help us to understand what should we fix for Quest sideloading - we'll try this!Knochi wrote: Fri Sep 27, 2019 10:16 am Hi,
I did a new threat to get a bit more focus on that, cause a many people own a quest and i thing it's THE headset for that kind of stuff.
Cu Knochi
I already tried the manifest changes proposed by oculus and others, without success.Maybe you want to give it another try.Realizator wrote: Fri Sep 27, 2019 10:25 am By the way, for uploading our Android application to Oculus Go we've changed manifest file. If you can help us to understand what should we fix for Quest sideloading - we'll try this!
Here is the official doc from Oculus:
https://developer.oculus.com/documentat ... -manifest/
and here a reddit Threat:
https://www.reddit.com/r/OculusQuest/co ... um=ios_app
Here is updated .apk with new manifest
Also i fixed green screen at secondary runs.
Works fine on Oculus Go, please, test it on Quest.
No run on Quest. I see live stream only in Skybox with a great latency.
It's bad :-/kru64 wrote: Mon Oct 07, 2019 5:09 pm No run on Quest. I see live stream only in Skybox with a great latency.
We need a Quest for tests. Will try to find one.
Not installs or not found in Library -> Unknown Sources -> com.virt2real.stereopi ? Or not starts? Any error messages?kru64 wrote: Mon Oct 07, 2019 5:09 pm No run on Quest. I see live stream only in Skybox with a great latency.
Apk installed OK. See it in com.virt2real.stereopi. Run, but none start.
I just got a quest last week, tried the new APK and had no luck with mine either.
Is there anything I can do to help?
Deluxe Stereopi + CM3 lite
Has anyone had any success yet? I'm curious as to whether it would work by setting the quest to 3dof mode? I'm unable to test this myself at the moment as I'm currently away but might be worth a try
We got Oculus Quest and was trying to solve this task for a week. A lot of new experience, but no success.Mr-Qu33f wrote: Fri Nov 08, 2019 3:15 pm Has anyone had any success yet? I'm curious as to whether it would work by setting the quest to 3dof mode? I'm unable to test this myself at the moment as I'm currently away but might be worth a try
Debug shows that our application (workable at Go) is:
- starting (black screen with a dots)
- discover StereoPi's IP address
- requests video stream
- decodes it and send to visualisation
After that application dies in approximately 20 seconds. Looks like visualization part is broken, and decoded video buffer is overfilled. We've tried a lot of fixes and approaches, but this thing does not work. I think we'll stop our investigations at this moments. All external programmers (with Oculus experience) was unable to solve this task. We were unable too. Unfortunately, this task needs too much time.
We can spend a day or two more, if you have some suggestions for us to check.
Do you have the adb logcat log to see what point it crashes?
Was any one ever able to figire out how to get the stereopi to livestream to the oculus quest?
Nope... Not yet.Snakinola wrote: Sat Apr 25, 2020 12:36 am Was any one ever able to figire out how to get the stereopi to livestream to the oculus quest?
Hi guys,
considering a StereoPi, but I only have a Quest. Is there still work/research being done on pairing those two devices together?
What would be a good starting point? I do have some development skills so maybe Ill be able to figure it out.
Hi Buhrmi,
Well, we have two news here.
Bad one: we gave up the h264 idea for the Quest, as it appears extremely difficult.
Good one: we're trying to do MJPEG-based solution, and in contact with one experienced developer, who did a good Unity asset for the real time video livestream to Oculus Quest.
Any news on the oculus quest solution? Looking to do VR streaming with stereo pi...evaluating possible options right now.Realizator wrote: Mon Jul 13, 2020 10:16 am Hi Buhrmi,
Hi bonnaroo,
Yes, one Unity-based solution is currently under development now.
