Distance between Lenses?
DaGlockoma
Post by DaGlockoma »
Good afternoon!
Looking to get this set up and have 2 questions, another I'll post elsewhere.
Does anyone have the distance between the optical center of the two lenses? This could be measured from one edge of one lens, to the other lenses same edge.
Need to know if my set up will work!
Thank you
Dave
Re: Distance between Lenses?
The "default" distance is 65 mm since it's the average distance between humans' retinas.
You can adapt this to your task. The bigger the distance, the better results you have for far objects, but closer objects won't be detected on the depth map correctly.
