Vertical Shift between left and right image
stoffel61
Post by stoffel61 »
I bought the StereoPi v2 no CM4 Camera Kit, because I didn't want to have any problem with
the alignment of the cameras. I put everything together and started SLP. That works fine so far,
but I have quite a strong vertical shift between the left and right image. What is the problem
here?
Regards,
Chris
glowingskull
Re: Vertical Shift between left and right image
Post by glowingskull »
I have a minor vertical shift between the left and right images. It sounds like we both have a physical misalignment of the cameras relative to each other. I would suggest resettling them on the backplate.
