Hello all.
I am doing SLP tests on a Raspberry 3 while waiting for the delivery of my StereoPi V2.
I have a problem with the StereoPi app for Android: it cannot find SLP! However, the connection with the IP address works.
My router's DHCP assigns IP addresses from 192.168.0.2 to 192.168.0.250 (with 0). Usually, 192.168.1.xxx is used (with 1). Is this the cause of the problem?
Thank you in advance for your answer
Marcel d'Alsace en France
StereoPi application not found SLP
Re: StereoPi application not found SLP
Hi MarcelC,
Our Android app is rather old and designed for the SLP v1. The video format is compatible, but the signalling part (handshake, network discovery etc.) has been updated. The latest app was designed for the Oculus Quest, and we'll do an Android app soon.
To do the fast test you can turn on the live stream using the "UDP stream" field, and put an IP address of your Android phone and a port 3000 to the appropriate field, like 192.168.1.173:3000
Thank you Eugene for your quick reply.
I had already tested the direct stream with VLC. It works but the latency time is a bit long (about 1s).
I will wait a little longer (I have been waiting for my StereoPi V2 kit since April ...) until the new versions of the applications are available.
I also develop in Android. Is it possible to get the source code for the Android app?
I am also interested in the source code of the "raspivid" command that you modified.
My project is to use the StereoPi with a binocular magnifier (to solder SMDs) and 2 cameras placed on the eyepieces.
Kind regards
Marcel
Kind regards
Marcel
srathinagiri
Any new version for the Android app for V2?
