Accidentally deleted Config
Other software discussion
Harbinger
Post by Harbinger »
Accidentally deleted the config file. Any idea where I can get a copy of the code to cut and paste?
Re: Accidentally deleted Config
Hi Harbinger,
If you are talking about the SLP v1 configuration files, they can be found in the disk image. All donloads links are collected in the wiki.stereopi.com, right bottom corner of the main page.
I'm attaching both stereopi.conf and config.txt from the /boot partition of the SLP image.
Archive.zip
(2.06 KiB) Downloaded 940 times
