I'm trying to do a livestreaming to a web with the StereoPi using the Rasbian OS and python. I'm not sure if for the SLP image has been done it with python or any other way.
I was going to try to do it with OpenCV but as I saw in the forum is not a good way to make a livestreaming video. There's a way to do it with Python or is better using another way?
Also, I'm not using the SLP because I'm not sure if I can adapt it to the project I'm trying to do. What I want to do is:
1) Display the livestream via web
2) Control the StereoPi from the web, sending messages to the StereoPi (forward, backwards i.e.)
3) The messages receive by the StereoPi also will be send to another controller (motor) via Bluetooth by the StereoPi
If it is possible modify the SLP image to also allow it to do something like that or even better to implement python programs on it, that will be amazing cause it will take a lot of work out of the project.
Thank you for your help and time!!
PS. If anything is not clear please tell me because my english is a bit rusty since I didn't use it in a while
