1.44" TFT screen Waveshare
Posted: Fri Jun 21, 2019 12:51 pm
I've got one of these tiny funny screens
So after following this manual with this fix I got this result:
Looks like new guides are coming :-)
Re: 1.44" TFT screen Waveshare
Posted: Tue Jun 25, 2019 12:30 pm
by stereomii
Realizator wrote: Fri Jun 21, 2019 12:51 pm I've got one of these tiny funny screens
Looks promising, although I think it will be difficult to package this nicely with my stereopi. Probably requires new case or add it to the outside of existing case with 14 soldered wires ;)
Posted: Wed Jun 26, 2019 10:52 am
stereomii wrote: Tue Jun 25, 2019 12:30 pm Looks promising, although I think it will be difficult to package this nicely with my stereopi. Probably requires new case or add it to the outside of existing case with 14 soldered wires ;)
I'll try to do it solder-less, and will put my solution here. :-)
Posted: Sat Jun 29, 2019 10:35 am
Realizator wrote: Wed Jun 26, 2019 10:52 am I'll try to do it solder-less
Lots of people use this kind of jumper wires for prototyping [first link, not a recommandation]
https://www.amazon.com/MCIGICM-40Pin-Br ... 07PLZC26F/
Posted: Fri Feb 21, 2020 3:22 am
by MauriceCyril
Hi everyone, is there an updated guide on how to set this screen up with the stereopi?
Posted: Fri Feb 21, 2020 9:00 am
Hi MauriceCyril,
At the very beginning of this post there are two links for the manual with all the steps you need.
Do you have any problems while installing? Which Raspbian image you're using for that?
Posted: Mon Feb 24, 2020 11:45 pm
by MauriceCyril
Thanks so much will check them out. I thought there was a new consolidated guide that I was missing.
Posted: Tue Feb 25, 2020 7:54 am
Hi MauriceCyril,
You see, installation of this screen has no any problems, that's why we did not post any additional guides. The only difficulty I found was incorrect settings in the original guide, so I've posted second link to the RPi forum with the fix.
