I'm setting up the StereoPi v2 Camera Kit using the Quick Start Guide and I'm having trouble getting a connection and stream from the cameras. I've only been able to detect 1 using get_camera
root@stereopi:~# vcgencmd get_camera
supported=2 detected=1Code: Select all
root@stereopi:~# raspivid -cs 0
mmal: mmal_vc_component_enable: failed to enable component: ENOSPC
mmal: camera component couldn't be enabled
mmal: main: Failed to create camera component
mmal: Failed to run camera app. Please check for firmware updates
root@stereopi:~# raspivid -cs 1
mmal: Cannot read camera info, keeping the defaults for OV5647
mmal: Could not select camera : error 3
When using raspistill-v -o test.jpg I get this output
root@stereopi:~# raspistill -v -o test.jpg
"raspistill" Camera App (commit 0093675e4aa6 Tainted)
Camera Name imx219
Using camera 0, sensor mode 0
GPS output Disabled
Quality 85, Raw no
Thumbnail enabled Yes, width 64, height 48, quality 35
Time delay 5000, Timelapse 0
Link to latest frame enabled no
Full resolution preview No
Capture method : Single capture
Preview Yes, Full screen Yes
Preview window 0,0,1024,768
Opacity 255
Sharpness 0, Contrast 0, Brightness 50
Saturation 0, ISO 0, Video Stabilisation No, Exposure compensation 0
Exposure Mode 'auto', AWB Mode 'auto', Image Effect 'none'
Flicker Avoid Mode 'off'
Metering Mode 'average', Colour Effect Enabled No with U = 128, V = 128
Rotation 0, hflip No, vflip No
ROI x 0.000000, y 0.000000, w 1.000000 h 1.000000
Connecting 2 x raspberry Pi camera V2 to the stereoPi gives, Cams detected 0, supported 2 in the camera settings of stereopi.local.
running the raspivid -cs 0 and raspivid -cs 1
mmal: mmal_vc_component_create: failed to create component 'vc.ril.camera' (1:ENOMEM)
mmal: mmal_component_create_core: could not create component 'vc.ril.camera' (1)
mmal: Failed to create camera component
mmal: Camera is not detected. Please check carefully the camera module is installed correctly
Any help would be appreciated, thank you
