Raspberry Pi cameras (V1, V2, wide angle etc), HDMI capture modules etc.
Sencis
Posts: 4 Joined: Fri Dec 10, 2021 10:09 am
Post
by Sencis » Thu Dec 23, 2021 12:16 pm
Is there a way to capture (video0 & video2) with GStreamer in one pipeline?
This method displayed the image of only camera 2, it was expected that both images will be displayed together on the left and right, respectively.
" gst-launch-1.0 max-buffers=1 drop=true sync=false"
" v4l2src device=/dev/video"+ std::to_string(device_1) + " !"
" video/x-raw,"
" width=(int)" + std::to_string(capture_width) + ","
" height=(int)" + std::to_string(capture_height) + ","
" format=GRAY8,"
" framerate=(fraction)" + std::to_string(framerate) +"/1 !"
" appsink"
" v4l2src device=/dev/video"+ std::to_string(device_2) + " !"
" video/x-raw,"
" format=GRAY8,"
" appsink";
Sencis
Post
by Sencis » Fri Dec 24, 2021 9:21 pm
it seems this is how it works
" gst-launch-1.0 -e"
" v4l2src device=/dev/video0 ! videorate !"
" video/x-raw,"
" width=(int)640,"
" height=(int)400,"
" format=GRAY8,"
" framerate=(fraction)50/1 !"
" m.sink_0"
" v4l2src device=/dev/video2 ! videorate !"
" video/x-raw,"
" width=(int)640,"
" height=(int)400,"
" format=GRAY8,"
" m.sink_1"
" glvideomixer name=m sink_1::xpos=640 ! video/x-raw, width=(int)1280, height=(int)400, format=GRAY8, framerate=(fraction)50/1 !"
" appsink max-buffers=1 drop=true sync=false";
Posts: 938 Joined: Tue Apr 16, 2019 9:23 am
Post
by Realizator » Mon Dec 27, 2021 2:14 pm
Hi Sencis,
Am I got you right that you are using HDMI output and HDMI capture device to get video frames?
Post
by Realizator » Tue Jan 04, 2022 9:55 pm
Uh, got you, thanx!
We've tried to use glvideomixer for bigger resolutions and color images, but the performance was poor. The idea was to find the workaround for the stereoscopic mode until the Bullseye new video subsystem fully supports it. Now we're still on Bullseye.
