If I run
raspistill -cs 0Code: Select all
raspistill -cs 1Running
raspistillCode: Select all
raspistill -3dI can happily get grabs from a singular camera using a simple python script:
from picamera import PiCamera
import time
camera = PiCamera(resolution=(480, 320))
time.sleep(2)
camera.capture('jpeg-test-shot.jpeg')
import time
camera = PiCamera(stereo_mode='side-by-side', resolution=(480, 320))
time.sleep(2)
camera.capture('jpeg-test-shot-stereo.jpeg')
Please not I am not running any particular version for any particular reason, so please tell me if you spot conflicting versions please point this out for me. This issue seems to be similar to the Raspbian Buster kernel issue from this forum:
https://forum.stereopi.com/viewtopic.php?f=9&t=744
Fortunately I am at a stage in this project where I am free to fresh install the OS and all software on the StereoPi and not lose any time. It would be good if someone (possibly an administrator) could point me towards a known set of working compatible versions? What is the most stable known combination?
(Results from running cat /etc/os-release)
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
NAME="Raspbian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
VERSION_CODENAME=stretch
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
(Python Version)
Python 3.5.3 (default, Sep 27 2018, 17:25:39)
[GCC 6.3.0 20170516] on linux
Type "help", "copyright", "credits" or "license" for more information.
